I've had this setup for a little over a year now, almost exclusively for bird photography (purely a hobbyist). I am definitely more of a birder than a photographer, so apologies in advance for stupid questions or general cluelessness.
In recent months, I have gotten the impression that the auto-focus performance on my camera/lens has gotten worse. Even at high shutter speeds and in good lighting, I am having a harder time getting birds in focus. Even when it appears that I have gotten the subject in focus in the viewfinder, I find that more of my images are coming out with this hazy blur around the subject upon opening them up on the computer. I fear I may have caused some damage to the camera when I tried to clean the sensor a few months ago. I had some stubborn sensor spots, so I used a cleaning kit and made sure to be very careful. However, I did not realize that I was apparently supposed to enter cleaning mode beforehand and leave the camera on to lock the in-body image stabilization. Could this have caused damage that would explain my possible image quality issues?
Unrelated to the sensor cleaning, but I have also noticed that I am experiencing some unusual resistance when extending the lens from 70mm to 350mm and back. I have never dropped the lens or banged it up to my knowledge. Don't know what the deal is there or how concerned I should be, just figured I'd mention it.
I've included an example image from today, significantly cropped and resized to meet the max upload limit. Also included a zoomed in section to show the type of blur I find myself experiencing more and more. Image details: ISO 125, 1/1000s, f/6.3. This was not intended to be a "good shot," just intended as a test of my auto-focus with a relatively close and slow-moving bird.
I am feeling like I should probably take my setup to a shop for closer inspection, but any advice here would still be appreciated. Even if the advice is that I don't know what I am doing and just need to adjust some settings.
  • 4 months later...
Hi
I have the same lens in my a6600 setup, and have not seen any comparable issue with AF accuracy.  Nor do I understand it to be necessary to make any preparation for sensor cleaning other than to turn the camera off (AFAIK, this locks the sensor down).  I have cleaned the sensor several times in the 3 years or so I have owned it.
Did you find a solution to the problem?
