    • Hi Guys, I have a Sony a6000 bought second hand. It's working fine but the photo capture from video function in the playback menu is missing. I've updated the firmware to 3.21 from 1.00 but the option is still missing. I can now shoot in XAVCS but would like to grab still images from the video. Anyone please?
    • Some questions to help you formulate the answer to your own question: In what sense do you feel your 70-350 is lacking? What do you hope to gain from this 'upgrade'? What % of your shots are in the 70-200 range? If this % is significant, the 200-600 is not an option unless you carry two cameras or don't mind lens swapping. What % of your shots is at 350mm and potentially could have benefitted from more reach? Do you need high resolution shots or is cropping in post an option to fix your compositions? Would carrying a lens over twice as big and over 3 times as heavy have a negative impact on your photography (think of fun, mobility, physical strain, packing volume)?
