Hi
I'm not sure if this an actual issue or just the way it is. I can't get the Focus Magnifier (will be referred to as FM) to work in Move mode.
I have it set for the Center button (can't remember if that's the default or not). Here's a video showing the problem (sorry it's a bit dark and shaky).
https://youtu.be/nq08U0ZVExY
1. Showing FM works in M mode and AFS.
2. Changing to MF, FM still works fine.
3. Changing to Movie mode, still in MF, I get this message:
This operation or setting not available as follows
Focus Mode
Manual Focus
It's not clear whether it needs to be in MF to work, or doesn't work in MF, but as shown in 2 and 2, when I'm in M mode, it works both in AFS and MF.
4. Changing to the only other focus mode that works in Movie mode, which is AFC, I get something different when using the Center button, Lock-On On/Off.
I really hope I'm just missing something...?
Thanks
I think it's just the way it is.  If you think about it, in video mode you are presumably shooting a moving subject.  When would you have the chance to use the magnifier to achieve the extra precise focus of the subject?  By the time you do get the subject finely focused, he she or it may have moved out of the frame, moved forwards or backwards, etc.  Which means you will have to refocus all over again.
Thanks, but even if that was true, it doesn't really make sense. Why disable it? You can always just... not use it. In reality, it's not true. More than a few times I have the camera on a tripod and take a video with the focus remaining the same. For example a frame of a full stage with performers staying in the same places throughout. This is just one example, and the one I had when I discovered this issue. In some of those cases I could even do with AFS, but that is also disabled in Movie mode for some weird reason, so there's the annoying workaround of framing in Movie mode, changing to M mode, focusing, then back to Movie mode. I'd still prefer manual focus with magnifier in most of those situations, which requires the same workaround.
I hear you.  Even though I am not a video shooter I can see situations where magnified accurate focus can be beneficial to have but since it's Sony who has decided to disable this feature in video mode there isn't much consumers can do.  What about other manufacturers, does any of them have magnifier focus feature in video mode?
Problems solved! I'm not sure why it took so long to figure out, and how no one in any Sony forum or group thought of it... but the problem was the custom key for the Center button was different from the stills. I don't know why, maybe it's the default, or maybe I changed it by accident and didn't notice. All the video custom keys were set to "follow stills", except this one for some reason, which was set to Lock-On, which obviously doesn't work in manual focus and this is why it gave the message.
    • Hi all, For about the last 1.5 years I've been using the Sony a7CR combined with the 24-50mm f2.8 G lens as one of the lenses that basically lives on my camera. Besides this I have the following lenses as well: Sony 16-25mm f2.8 G Sony 14mm f1.8 GM Sony 40mm f2.5 G Sigma 85mm f1.4 On my last travel I took the above mentioned lenses with me + the 24-50 G. Would have most likely taken the Sony 14mm f1.8 GM but I didn't own this yet at the time. For my next travel I do want to take this as well so then my setup would look like: Sony 24-50mm f2.8 G Sony 16-25mm f2.8 G Sony 40mm f2.5 G Sigma 85mm f1.4 Sony 14mm f1.8 GM At this point I feel like I'm kinda reaching a bit of a limit in terms of lenses I want to take with me during travel, especially the 85mm. I wish to use it more but noticed I often left it at the hotel/apartment room I was staying at. Initially I bought the a7CR for weight savings but as time has passed I do feel certain limits with the setup especially during travel/landscape (as this is my main form of photography). And that's mainly coming from the amount of lenses I'm taking. I have been considering to trade in the 24-50 G lens to the 24-70 GMII to use on my a7CR but after using my Sigma 85mm f1.4 for an extended time on my a7CR it does feel uncomfortable to use due to the front heavy nature of the setup. The 24-70 GMII would be about the same weight as the Sigma. One option would be to use the extended grip on my a7CR, this certainly makes handling a lot better of bigger lenses but I usually have my setup hanging from the Peak Design Capture Clip on my backpack and I'm not sure if the extended grip really designed to take this much weight to be fair. Maybe anyone here has experience with this? So what this leads me to was the consideration to upgrade to the a7RV + Sony 24-70 GMII as there are some good trade in deals going on right now where I'm at. I'm not sure is this setup an absolute overkill for a hobbyist photographer... :) The benefits of this upgrade would be to have less need for changing lenses during travel and reduce the amount of separate lenses I have to take with me. The overall weight would however be approx. the same that goes in my backpack. Usually when I'm out for hikes I will currently only take the 16-25 & 24-50 with me. With this setup the reach feels limiting even with cropping the 50mm to 75mm (still approx. 26MP on the a7CR after crop). What I usually use my setup for: Landscape photography Travel Portrait Astrophotography I was wondering is there anyone here who went from a lighter a7CR (or similar) setup to a slightly heavier setup to carry around during hikes etc. Did you regret it or was the tradeoff worth it? As mentioned I do feel like my current setup is somewhat limiting and realized that switching lenses during travel is an absolute pain in the ass. But I'm not sure if the extra 450gr (about 1 lb) is worth the tradeoff. I know the decision is ultimately up to me but just like to hear your thoughts on this upgrade, and if the additional features & image quality in trade for weight would be worth it as well. TL;DR: Looking to upgrade my a7CR 24-50G f2.8 setup to a7RV with 24-70GMII f2.8 lens, not sure if it's worth it with the additional weight in trade for more versatility and better IQ. Thanks in advance for your replies!
