This lens is somewhat soft close up, but tack sharp further out. I'm disappointed because it's an ideal focal length for me: the sharper macros in the 70-90mm range have too narrow a field of view for a lot of what I like to do.
I don't' need auto anything and I'll be looking at my old Nikons & Minoltas, but suggestions & observations are appreciated.
