Flange focal distance of Fujifilm X cameras is 17.7 mm and Sony E mount is 18 mm so it's impossible to adapt X mount lenses to Sony systems, even there is a physical adapter, you only can use them as macro lens and you even have to focus by legs since the focus barrel cannot work without power supply.
The same is true to Canon M or Nikon 1. The only possible case is adapting these lenses to Pentax Q since the flange focal distance is only 9.2 mm.
There is only possibility to mount Samsung NX lenses to Sony E, but still no electronic adapter for this. And it's possible this in case to make it 25mm vs 18mm flange distance difference makes it possible...
... and a poorly corrected
"corrective optic" at that !
There's an optically better
way to do it, but then the
adapter is also a TC, altho
it can be rather mild, such
as 1.2X. Minolta sold one
in the early Maxxum years.
It also provided speedy AF
by shifting the TC elements.
Nikon also sold an "AF-TC".
It adapted Nikon-to-Nikon,
but it also provided fast AF
with non-AF lenses.
