August 8, 20196 yr Hi everyone, first time post and first time user of my new, old, a350. I’ve come across from a FujiFilm S2Pro and after being initially impressed with features and ease of use. I’m left feeling a little bit frustrated with the colour rendition from the lenses and numerous setting changes I’ve tried. I can’t seem to get the colours to pop, like my old Fuji. It’s perhaps that the Fuji was a Pro camera or just that i’m not setting the Sony up correctly. I’m hoping that this forum will help ease my my and hopefully give advice on settings that will help. Thanks.
August 8, 20196 yr Go here to the manual —> https://www.sony.com/electronics/support/res/manuals/3287/32879691M.pdf search for vivid
August 8, 20196 yr Author Thanks, yeah I tried that but I didn’t think it made a huge difference. I’ve tried changing the colour temp and doing a spot metered white balance!
August 8, 20196 yr It may be that you need to do some post-processing to get the results that you want. It seems every camera interprets colors differently.
August 14, 20196 yr On 8/8/2019 at 10:01 AM, Macleod82 said: Thanks, yeah I tried that but I didn’t think it made a huge difference. I’ve tried changing the colour temp and doing a spot metered white balance! Do you have Affinity Photo or Adobe Camera Raw? Those tools will allow you to get the results you’re looking for, point blank period.
August 14, 20196 yr Author Neither i’m Afraid, I’ve photoshop elements and I can install Apples Pro photo software. I’d been hoping to stay away from Post edit and capture the moment, in camera. I’ve since found after looking at the photos; I’d been having issues with. That the LCD viewer is slightly at fault under representing the colour values and photos taken at the medium to long focal length seem to suffer the drop off in colour. The Vivitar lens that came with the camera is good and well made, however longer shots are not as colourful; could be that there’s no filter or just a quirk of the lens type and size 72mm? Thoughts.
August 15, 20196 yr 19 hours ago, Macleod82 said: . I’d been hoping to stay away from Post edit and capture the moment This is ok however never underestimate post processing, sometimes it brings out the moment. Take a look at these reds and let me know if they are to your taste I just did minor post processing to over saturate the reds, the editing is pretty basic I just didn't want the image to look over processed. What would you do different? Also, try a polorized filter, are you shooting in RAW? It could be your RAW processing color gamut is off slightly, if you would kindly share one of your RAW photos for me to have a look. Thank you
