Sony A7 II - EVF Noise in high Light
Hi,
I just have a new Sony A7 II, when I look through the viewfinder (EFV) towards a sunny area, there is low noise/grain on the image, it is not net like the outer screen LCD. After shooting the picture, the image on the viewfinder becomes net. There is no problem when I see towards the low light area.
Is it normal?
Thanks very much,
Best regards,
