Sony A7x Shutter Count
MikeTison
Just out of curiosity, What model A7 are you using and whats your current shutter actuation count? Also, it would be great to list at what shutter actuation count if you have had any problems or needed any services done..
Thanks SAF!
Mine-  A7ii @ 12,547.. no problems (knock on wood)
