Good evening everyone. I recently bought an A9, and coming from Nikon I have some questions.
1: Is it possible to select some photos from Card 1 and copy them to Card 2?
 On my Nikon, I used to do this: Protect some photos from card 1 when I finished a shoot, then copy only them to card 2 so when I put it in the pc, I only had those raw files selected before, and don't have to search among all raw files of card 1.
2: Is it possible to assign to a button the possibility to open the My menu screen?
These are the questions that come in my mind for now.
Thanks in advance
1. No there is no option to copy files from one card to another. The new α7RIII has a rating function that will be recognized by C1, Lightroom etc so you can readily identify your best shots to speed up import times, I suspect that it will only be a matter of time until that option is added to the α9.
2. There is no function to open the MyMenu at this time. I would like to see an option to open MyMenu if the MENU button was pressed twice quickly. The menu should open to the last viewed menu item, so if you were viewing MyMenu when you leave the menu system then the next time the MENU button is pressed it should return to that same screen..
