April 28, 20178 yr This is the first result of my new Lee nd-grad filters. I have never used grads before, so I'm still learning and I was a little surprised that I found it quite hard to see how it graduates on the lcd-screen on my A6300. Need to get used to it, I think. This shot was taken with a A6300 and a Batis 25 with a 2 stop hard grad filter. Can anyone give me some advise on how to lighten up the barn a bit?
Advertisement Hi beunky, You may be interested in this: Road to a barn . I'm sure you'll find what you were looking for!
May 3, 20178 yr I'd use an editing software like PS or GIMP, create two layers of the same image, correct the brightness of the barn in the background image and then apply a soft eraser tool to the top layer with your current image in the area of the barn... Can anyone give me some advise on how to lighten up the barn a bit?
May 3, 20178 yr You could also use the brush tool with very soft feathering in Lightroom to lighten up the barn a bit.
May 3, 20178 yr Author I tried it with both methods, can't seem to get the brush tool method working now. I must be doing something wrong, so I should research the brush tool function on youtube I think The correction is quick and quite rough, a little more refinement alongside the edges and a little less extreme brightening it up should do the trick better.
