i just got the a6000 i'm starting to like it the more that I learn about it. One thing that I don't like is that
the marco mode .... how shall I say.... isn't very good. I like macro photography a lot so this is very disappointing. Have any of you had any good results with any macro lenses? Either Sony, aftermarket or old lens from other cameras.  I don't thnk I want extension tubes but I wondered if there was a lens that screwed onto the front of the 16-50 lens? I also don't need to be right on top of the object either.
Maybe this next question should be another discussion started but I have an old Olympus OM-4 with some nice lenses and I wonder if there is an adapter to be able to use any of those lenses. I know that I would have to do focusing and maybe apeture manually as these don't have much in the way of elecrtonics. lol...
thanks all
marty - Sony makes a macro lens.  If you want to look up prices, reviews, etc it's: SEL30M35 30mm f/3.5 e-mount Macro Fixed Lens  When I bought my a6000 I bought 4-5 lens including this one.  It's okay I guess.  It is not stabilized so be aware of that.  I don't use it enough to justify keeping it so I'm going to sell it on ebay with a lot of other stuff that I'm selling.
I use my a6000 for macro even more than my FF bodies.
Most of my cameras are 24MP and if I use the larger
cameras I wind up cropping down to 12MP. The a6000
provides that crop, and maintains 24MP :-)
As for optics, I work at high imaging ratios so optics are
not that critical. A huge tripod and tiny f/stop equalizes
all lenses ... at least optically. But I use dedicated macro
lenses for aspects other than IQ. The a6000 has no real
tripod interface. Yes it has a threaded hole on the bottom
but thaz rather useless. So I prefer a macro lens that has
its own sturdy tripod interface.
Other reasons I use dedicated macro lenses are the fairly
obvious stuff ... built-in close focus ability, 100 to 200mm
FLs, very small minimum aperture. I also depend on a
focusing rail for final focus. Using the lens helical for final
focus can drive you nuts.  Worse yet is moving your tripod
for final positioning. The rail is your "zoom".
Just get any appropriate macro lens, IOW not a zoom and
preferably with a tripod interface. I have 4 different Micro
Nikkors, plus Minolta and Sigma macros. You cannot tell
the images apart.
Yes there is an adapter, many adapters, for your OM lenses.
The Metabones is much better than the cheaper ones. But
the Novoflex is no better than the Metabones even tho it is
about twice the price. IOW, get the Metabones ... unless the
$70 premium for skipping over the cheap versions will leave
you living in a cardboard box.
If you use a front mounted close up lens on your
kit zoom, your rig will be light enuf to be trusted
to the minimal tripod interface of the a6000 body.
You'll need to stop way down for DoF so optically
the added optics do no visible harm to IQ. If you
wanna try it with no tripod, realize that the OSS
will be less effective ... reduced but not useless.
The OSS knows the image magnification at all
normal zoom and focus settings. When you add
the close up lens, you have more magnification
than the OSS "thinks" you have. Don't shut off
the OSS but allow for a reduced benefit from it.
Steadiness is important in another way. Forcing
a zoom, especially compact kit zoom, into macro
service brings about significant curvature of field.
THIS IS NOT DISTORTION. It means that the
presumably FLAT field of focus is no longer flat
but curved. IOW the entire sensor-and-lens is no
longer focused to just one distance all across the
format. If it's focused to 15" in the center, it may
be also focused to 12" half way out to the edge
and only 9" at the far edge or corner. Bottom line
is that if you shift your aim AFTER focusing, you
shift not only your aim but also your focus :-( It's
quite possible that your disappointment with the
macro ability of your kit lens is due to your being
unaware of the focus effect of curvature of field.
Working carefully, you CAN get very fine results
withing the built-in macro abilities of the kit lens.
the images apart.
tripod interface is a term i'm not familiar with. is it a focus rail you are refering to? thanks
that sony sel sells for 253.00 on Amazon. what do you think that you might want for it just in case i might want to go that way?
I use the term "tripod interface" to refer to the camera's ability to interact successfully
with a tripod. Having a threaded hole in the base plate is NOT any guarantee of success.
Consider the size and strength of the area surrounding the hole. Also, for two different
cameras with a similar flat area surrounding the threaded hole, the camera with the hole
located further toward the back of the camera has the better interface, cuz we add weight
to the front of the body [big lens, etc] but not to the back. OTOH if we flip the rig to vertical
format, then the rearmost hole is a problem, cuz lens weight causes the the whole deal to
try to rotate to a lower aim than desired ... unless we overtighten the tripod screw.
There are "cradles" and "cages" for compact camera bodies that greatly improve their
tripod interfacing.
Most Sony APSC bodies have a miserable tripod interface. When I use a macro lens that
has no tripod interface on it, I'm glad I'm using an adapted lens, cuz all my adapters have
better tripod interfaces than the Sony camera bodies. Even the A7 series is only a small
improvement over the APSC bodies in that aspect. So .... when you consider a dedicated
macro lens, do consider one that attaches via an adapter if the lens itself lacks a built-in
tripod interface. Acoarst not ALL adapter have an interface :-(
When using an adapter macro lens with built-in tripod interface, I skip the interface on the
adapter cuz the one on the lens has a big advantage: It allows rotation around the axis of
the lens so I can level the horizon or rotate to vertical format without resorting to the huge
motion involved in using the tripod head for that purpose.
A good choice is a Metaobones E-N/F adapter and an old 105mm Micro Nikkor with its
built-in rotatable tripod interface. You can also adapt to A-mount, but A-mount lenses are
waaaaaay harder to find than Nikkors. However, if you shop for the lens first and let the
lens you find determine what adapter you need, then you might get lucky and find an A-
mount lens which would allow you the luxury of an auto-iris coupling. Sony's adapters do
have a decent tripod interface.
martygene - most likely I would get $200 - 215 on ebay for that lens.  All this talk about tripods are confusing to new users.  I've hand held macro shots and they are fine.  If you want to make sure just put your camera and lens like that on a good tabletop tripod and shoot away.  I have a mePhoto that suits my needs.  I've taken shots of knives that I've sold, cameras that I've sold, etc on ebay.  But the images I've had before I cropped them, reduced the file size and the resolution and such are fine and could be used on large prints if I wanted.  Don't get too involved in the "pro talk" as everyone in that bunch has their own opinions for their workflow and their end product may be for completely different uses compared to your work or what you want out of it.  If you buy a lens you don't like or get good results for they are easy to sell without losing much money.  Or rent one for 3-4 days, experiment with it and see what you think.
It depends on what kind of macro you will be doing. Macro rings is a very cheap and effective way of getting sharp macro shots with good background blur. The only negative is that you will be restricted to short working distances.
The macro filters won't give you as sharp images and you'll be similarly restricted to short working distances.
For macro work at varied distances and telephoto capability, you can choose a vintage maro lens with adapter. Manual focus is best for macro work anyway. The Tamron 90/2.5 or 90/2.8 is really nice as is the Minolta MD 50/3.5. Both are quite affordable.
Personally, I do a lot of macro work with the Tamron AF 90/2.8 (272) and LA-EA4 adapter on A6000. It's a very agile combo that lets you do angles. For serious work, I bring out the Sony 100/2.8, which is probably the most underestimated lens for A-Mount.
With my A6000 I use a Canon EF 100mm Macro f2.8L IS USM lens attached to either a Sigma MC-11 or a Comlite adaptor. I use manual focus, which I normally use for macro work anyway. The Comlite will try and autofocus, in autofocus mode, but is very slow. Focussing manually with the Sigma A6000 is very quick and accurate. The Canon macro lens is one of the best available. I originally bought it to use with my Canon 70D DSLR.
