My shooting buddy is a Sony pro.  He's using the e-mount A7M2 and the A7S and the RX1. I use the A7R.  Both of us are enthusiastic about our gear. We like the smaller, lighter profile of the A7 equipment.  We've been carrying the message to the masses that this is the way to go.  But, he's backsliding!  He confessed to me that he misses the larger traditionally 35mm sized bodies.  He's been eyeing my A900 and we have been rehashing the notion that commercial and/or sophisticated consumers of digital photo services tend to disdain the e-mount gear as nonprofessional.  The upshot of this is that in my opinion if Sony wants to market a "pro" e-mount, they are going to have to package it as a more substantial appearing system. The update of the A7 to A7M2 somewhat addresses that objective with a heavier frame and improved ergonomics. There may need to be a "flagship" model with a 50 mpxl sensor and onboard computer/communication enhancements. They may even have to raise the price of the "pro" just to be consistent with the exclusive quality image they are seeking to get across. The same thing that Cadillac does when it marks up its Chevrolet equivalent models by thousands of dollars. Sony might put out a "safari" model that a pro could take into a jungle war zone with confidence.
This is my thinking, I look forward to seeing what other responses you get.
I think with all systems that break away from the dominant tech, they will be treated with suspicion by many.
Personally I think the A series cameras are fantastic and in most aspects, every bit as capable as their Nikon and Canon rivals and in some areas superior.
Certainly in terms of absolute image quality my A7R outclasses any Canon sensor and that's the main reason, together with the weight factor, that I switched.
If Sony do produce a 'pro' A series body I think that they need to keep it within a similar weight catagory and with a competitive price to maintain momentum.
You've also got Fuji and Olympus producing first class smaller systems that are becoming increasingly popular.
Eventually the big two will have to look at downsizing their brick-like bodies as many photographers I've spoken to do get fed up of lugging around all of that weight.
So there is a rumor that there will be a Sony E mount Pro camera
released in the future what will that mean? High ISO capabilities,
Large Megapixel count, dual card slots? any one have any thoughts
on what "pro" is going to mean?
Nothing. it's a meaningless invented marketing term.
Means nothing. OK, it does mean something. It's an
antonym of "con", meaning "in favor of". We're all in
favor of Sony upgrading these products, right ?
......... Sony might put out a "safari" model .....
Get with the program. Standard issue imaging
gear for war zones is a cell phone. You don't
need expensive lenses and 50mp sensors for
that kinda of coverage.
    • I have a slight problem with my A7Riii connected with the auto-focussing. Occasionally it will not auto-focus at all and the image remains out of focus. Checking the FN function the focusing tab is greyed out and if I persevere it will say 'This lens not compatible or not connected' etc.  I have to remove the lens and refit it, making sure I push the lens hard.  This happens with all my lens so I suspect it is the camera. I examine the contacts, cleaned them all and examined the mount etc but all seems fine.  Just wondering if anyone else has had this problem and if it is fixable.
    • My Sony z7iii Camera sometimes sits for long periods (weeks) in its camera bag. I began having the problem of the camera 'forgetting' the date & time when I'd power the camera on. I learned that the internal ('real time clock') battery only gets charged when : 1.) The camera is turned-on (with the regular battery in the 'battery well') as when the camera is being used or 2.) When the camera is turned-off and a fully charged 'regular' battery is in the camera's 'battery well' and the external charge cable is plugged-in (and connected to the AC charger) (Typically I've found that the tiny  amber 'charging' LED comes on for a brief period when the external charger is first plugged-in but then it goes off. Apparently it is only then that the internal battery starts to be charged ... when the amber LED goes off.) When I looked into the situation I found that I was not the only person having the problem. Other a7iii owners had asked how to charge the internal battery and then Sony explained to leave the camera plugged into the charger for at least 24 hours. (I don't believe that this is covered in the Owner's Manual.) I have managed to charge-up the internal battery (at least enough such that the date & time is maintained for awhile) but I now question if 24 hours is long enough ? In late June (2025) I left my a7iii Camera plugged into the external charger for several days and 6 weeks later the camera still remembered the date & time (though the clock's accuracy isn't all that good) Does anyone have any evidence as to how long the a7iii needs to be plugged into the external charger to fully charge (as when the camera came from the factory) the internal battery ? (signed) - Paul, WB5AGF
    • a7RCII weirdness: Yesterday, after a few normally saved shots, my a7rcii began to record 3 identical images for each exposure I took. These were not bracketed in any way, all shot in AF-S mode, just 3 identical files with the expected sequential filenames. The metadata for each is the same except for the filename. Any ideas about what's up with this? I'll check the camera again later today.
