Handheld, late afternoon shot of tiny Hamlet in Tuscany.
And a hayfield in Umbria, also late afternoon.  This image made with the Zeiss 55mm f/1.8 (the photo of the hamlet in Tuscany above was with the Sony 70-200mm f/4.
