  • 4 weeks later...
    • I do a bit of astro photography and do a lot of research etc. on best settings to use. I have never heard of anyone using ISO bracketing! Typically, higher ISO settings such as 1600, 3200 or 6400 are used and multiple light and dark frames are stacked to reduce noise. If you are worried about noise in dark foreground areas then just use a seperate exposure for them then blend the exposures in post processing. By the way, I also have an A7R5.
