I just got my a7R II today, but I noticed it keeps having noise sound when powered on if you put your ear close to the grip area. The sound not loud, but audible when you put your ear close to it.
I thought it because of the IBIS, but even I turn the IBIS off, I can still hear the sound.
Doesn't the camera automatically use IBIS to clean the sensor each time you turn it on, regardless of IBIS being on or off ?
Yes, but I meant the continuous sound while powered on. The sound is very little, I need to put the grip close to my ear to hear the sound.
Yep, mine has a sound too.
And probably it's because of IBIS. Even when turned off, the camera is built different than DSLRs without IBIS. The sensor isn't fixed in the body. It's actually floating. When you turn the camera on it also turns on the electromagnets used to control the sensor. That instantly puts it in the standart position which makes the sound.
Thank you, but I didn't mean the 1 sec sound when the electromagnets started working, I meant the continuous sound while powered on, the sound lasts as long as I keep the power on. The sound is very little, I need to put the grip close to my ear to hear the sound.
http200--  I'll be doggone, it does it on mine too.  You're right in that it is so faint one has to put one's ear up to the camera to hear it, and I listened to it for about 20 seconds and it didn't go off.  It could be the 5-axis anti-shake.  -DA42
Thank you  :D
    • Do you know anything at all about photography, cameras, etc., or was this a purchase because of the trip? If this is your first entry into photography, ignore everything anyone tells you about settings, it will just confuse you. Put the camera in Auto and shoot, you'll be much happier.  Conversely, if you know about such things as shutter speed, apertures, ISO, Depth of Field, etc. etc., then you should already know that there is no such thing as a 'best setup' for an outing that will vary a widely as a safari. You will encounter everything from action to static shots, landscape, light, dark, the entire gamut. If it we me, I'd shoot in manual and make adjustments for each setting.  My wife and daughter went on Safari a year and a half ago. My daughter took her Nikon. My wife is not a camera person so I sent her out with a Kodak Easy Share 16MP something or other set on auto and told her to just press the button. We have several of her shots framed in 8 x 10.
    • Could be a good travel lens I guess. I'd wait until there are some reliable reviews.
    • You have left it until the last minute. I don't know much about the a6000 but I'd be using Manual mode with Auto ISO. Is it Africa you are going on safari? If so, I imagine there will be plenty of light most of the time. You need to set a shutter speed to freeze any action. I would probably start with 1/1000 sec. and set aperture to just below maximum and let the ISO get the correct exposure. Take lots of shots and keep checking to see if you are getting the results you are after. Good luck.
