As a new owner of a Sony A6000, I am thinking of buying a Neewer TT560 flash gun for off-camera use only, and wondered if anyone has any experience of these?
I already have a pair of Yongnuo triggers (RF603C ll), so I am hoping that the Neewer flash will work OK, but thought I should ask first.
I only require manual mode, not TTL, so this £27 flash should do all I need.
I also have a second question: To get the triggers to act as a remote to operate the camera shutter (from a distance, as designed), what specific cable should I look for (camera to trigger cable), as there are so many different fittings?
Any advice appreciated.
Thanks
