I bought a Sony a6700 earlier in June and have been very much enjoying it. However, I took some low light photos recently at very high ISOs and noticed horizontal lines across just the right half of the image. I'd expect a ton of noise at these ISOs, but I find it concerning that it's not uniform. I know it would be rare for this to show up in an actual photo, but I did discover it when taking a very low light photo of a room.This was a big purchase for me so I'm quite concerned I have a lemon! I know that it would be rare that this would
I was wondering if before I RMA someone could test to see if it's a quirk of the camera or I have a bad sensor. The easiest way to force/exaggerate the issue is to turn off high ISO noise reduction, crank the ISO to max and take a photo with the lens cap on. Also, if you could provide a jpeg or raw of it that would be amazing. An example of what it looks like is attached.
Thank you
I don't know why you would even try this to be honest. If the camera is operating normally under normal photographic conditions I would be happy with that. Just out of curiosity, what ISO did you set?
If you are unhappy with the performance of the camera then return it.
    • I am considering purchasing the Luminar editing program for IOS to use with my A7iv; however in listing which cameras are compatible, there is this statement: "Sony vcb cropped p send-raw format is not currently supported."  Does anyone know if this means that the program will not work with raw photos?  Has anyone successfully used this program editing raw photos?
