Hello all,
My apologies if this in the wrong place. I have an RX100 M7 & I've been trying to ascertain if there's a means of updating it's firmware? I have version 1 installed which came with the camera, however I cannot find a way to see if there's been updates & if so, how to install them.
Any help would be greatly appreciated please?
Thanks & regards.
Terry
I typed the address bar: "Sony RX100 M7 Firmware Update" and got this page:
Drivers and Software updates for DSC-RX100M7 | Sony USA
This is version 1.10 and appears to be the latest. It was released in 2015.
Instruction are included in the link. If you've never done this before, read through them first to make certain you understand the procedure, and follow them closely.
Edited by Cameratose
