February 20, 20241 yr Hi all, first time poster. I am getting back into photography and have chosen to stick with sony, I have a pretty old Sony A100 alpha on the A mount, I have a couple of lenses that are all AF enabled, a small 28-70 sony kit lens and a telefoto Minolta, so my thought was to get an a6000 body, and use A to E adapter to make use of the glass. Is this advisable? Will I get clear crisp imagines in this manner, I can't imagine these lenses would be classed as "too old" or would they? I'm trying to keep the initial cost down whilst I get back into things, after this i would be happy to spend a bit more. Happy for any advice or correct me if my thinking is wrong. Is the A6000 a decent place to begin? I also considered the A77 mk2, which has the A mount. To add, my style of photography is mainly just portraits, family time photography, and some outdoor street stuff from time to time. Thanks! Edited February 20, 20241 yr by Hosh
February 20, 20241 yr Why not get an a-mount camera -- with the features you want? There are lots to choose from. Most are APS format, but there were four that are full-frame format. To use a-mount lenses on e-mount cameras you need an adapter that depends on your a-mount lenses and e-mount camera. They are not cheap, and can have limitations. You can avoid all that by sticking to a-mount cameras -- which are usually inexpensive. So are a-mount lenses! Here's a list: https://en.wikipedia.org/wiki/List_of_Sony_A-mount_cameras Edited February 20, 20241 yr by XKAES
February 21, 20241 yr Author Hi bud Thanks for your reply, the A77ii is one that has the A mount my friend hence why I am very much considering it, having looked more over a few days I may take this route, as you have said though it has an APS sensor, so Additionally as starter should I try to get one of those A mount cameras with full frame or Aps for starters would be good? I don't mind spending a little more to have a camera that I really "grow" into Edited February 21, 20241 yr by Hosh
February 22, 20241 yr Since you are familiar with the APS format -- from your a100 -- you might want to stick with that format. The four a-mount cameras that are full frame are great, but more expensive -- but so are the latest APS format a-mount cameras (but they have newer features). The a700 is a winner in my book, but it may not have what you are looking for.
