Good morning to everyone !
The day before yesterday I made some rounds towards Delta of Nestos river at Greece
where there is a big drought..
It was sliding very very very .. Very very !!
Well, I also had the 1st, I would say jokingly, case.
Everything is fine, the engine was not damaged either.
The video was shot handheld and on a tripod,
I didn't emphasize at "luxuries" and props shots cause of the situation you will see.
Made with Tamron 28 75 lens & Tiffen mist 1/8 filter in front of the lens
Here's the video
