Hi guys,
I just bought a sony a6700 and the shutter stays closed.
Any idea how to get it fixed or any similar experience?
No repair shops in my country for such a camera and I bought it from a foreign country.
I get this message on the screen
"Camera Error. Turn power off then on"
