Sony HVL-F20M flash (or HVL-F20AM with Sony ADP-MAA adapter) will let you use your HVL-F58AM as WL remote with TTL/HSS and most features working. Should you find the F20AM with adapter, the adapter will also let you use the F58AM flash on camera.
The other trigger i use is the Phottix Odin system that is somewhat difficult to find with Sony compatibility. Its downside is that is does not work with adapted lenses that don't communicate with the body. If you only use native lenses that would not be a problem.
