Why is it that I have my range set to 102400 but the max ISO i can choose is 32000?
I'm shooting movies in slog3 and in a dim apartment, and trying to expose to the right, can't get my zebras to show up at 32000. I need to bump up the ISO more, but the camera doesn't let me.
thanks for the help.
My guess would be that in slog3 the camera can only shoot in 'real' ISO (which maxes out at 32000). When exposing to the right it makes no sense at all to shoot in the fake/extended ISO range: it doesn't give you any more dynamic range or shadow detail compared to raising brightness in post.
thanks for that. I knew there was a lower limit of 800 on my camera, but you're still "allowed" to go under... the ISO numbers have a line above and below to indicate, but there's no indication as to why you can't go over. I'm finding that in a dim (but no so dim) room at night that I can't get my zebras to appear at 94 for slog3, so I'm underexposing. I'd like to turn the ISO up as that's my only option besides lighting (which I dont have in every situation), but now I'm learning I can't. I thought slog3 was supposed to be good in low light but wondering now if to use something else for low light shots?
I know you might want the most dynamic range, but if you are shooting in a dim apartment and you have to raise the ISO to 32000, slog3 is not a good idea.
Try slog2,  and for best lowlight performance try Cine1, that is the lowlight king but with lower dynamic range compared to Log.
You can see some sample footage here using Cine1
Here are a couple Picture Profile Recipes I've been working on for the past couple years with the purpose of replicating the film look on sony digital cameras.
you've been really helpful w/ all my posts! I will check out Cine1, but at the moment playing with HLG3... not sure how it compares, but trying to minimize the number of profiles I use at least now since it's all so overwhelming starting out... will watch the vid now!
    • This is just a quick and dirty first try composite from my efforts the other night attempting to capture the Full Lunar Eclipse. I will refine this and do a version with a foreground over the next week or so. The weather reports weren't good, as far as cloud cover went, so I was thinking I may not bother with it. The afternoon ended up being sunny and warmish with only the odd cloud here and there. I got my gear ready just in case. Sunset was just before 6:30 and after that I was checking the sky every half hour. Just around midnight I decided I would give it a go so I made some coffee and some sandwiches and headed off. So anyway, long story short, I had to brave the cold, the wind, a heavy dew, sea spray (the sea was quite rough and the tide was coming in fast) and quite a bit of cloud just after the full eclipse. Anyway, I'm pretty happy with this first attempt.
    • I'm going for it. Yeah, it's a superzoom that has all the typical traits of a superzoom, but that 20mm short end is too good to pass up. This lens has been rumored for a couple of years; I can't wait to get my hands on it. If it's any good I'll sell my 24-105, I don't need a fast lens for the planned use.
    • Help! I am leaving for a safari in a few days and need help setting up my Sony a6000 for the best wildlife shots. I also have a Tamron 70-300 lens. I'd really appreciate any suggestions for the best settings. Thanks in advance.
