Hi,
I have downloaded the A1 1.2 Firmware update to my brand new MacBook Pro but when I Start the update a popup from "SystemSoftwareUpdater" comes up and says "You need to install Sony Camera Driver. Sony Camera Driver" then bunch of Chinese symbols.
I don't see a driver anywhere online that's generic. In the Sony A1 folder I downloaded a few other things but the popup continues to show up. Does anyone know how I can update the drivers on my camera?
Thanks!
John
On 1/10/2022 at 5:50 PM, araxara said:
You need the Sony Camera Driver for your M1 MacBook Pro. It's available at
https://www.sony.com/electronics/support/e-mount-body-ilce-1-series/ilce-1/software/00268925
This procedure is also explained in the A1 Firmware update page
https://www.sony.com/electronics/support/e-mount-body-ilce-1-series/ilce-1/software/00260271
Very useful. Thanks very much.
