I purchased a Sony A7III,A7II,A6300 and I'm having difficulty using it on real estate photo shoots. The real problem is when I turn on the camera mounted flash (X2T-S), the white balance changes to very warm, even when it's set to auto. When I'm not using the flash, auto white balance works great. I started setting the white balance manually but I have to do it for every shot which is very time consuming. I'm not sure what I'm missing but something is changing as soon as the flash is turned on.
I only use godox trigger X2T-S but it seems like if you set manual WB on the A7III,A7II,A6300 and put the flash in manual mode, the WB should stay put.
  • 3 months later...
