This is probably too dumb to ask but here it goes anyway.
Is this noise normal?
Here's is two screenshots of the same photo I took for testing purposes. One has a 1.50 exposure increase to make the noise even more visible.
Settings were: F3,5 @ 1/125 and ISO400
Thanks!
