I use the Tenba Solstice Sling 10L with all of the dividers removed. I can fit the Sony A7RIII, the Sony 100-400 mm with the hood open and 2x in it completely assembled and ready to shoot.
John
On 7/13/2019 at 1:25 PM, DrJohn said:
Thanks Dr John, looks like you also have the 2xTLC fitted - can you tell me what make this sling bag is please and approximate cost as I want to see if it is available in the UK.  Thanks.
    • Do you know anything at all about photography, cameras, etc., or was this a purchase because of the trip? If this is your first entry into photography, ignore everything anyone tells you about settings, it will just confuse you. Put the camera in Auto and shoot, you'll be much happier.  Conversely, if you know about such things as shutter speed, apertures, ISO, Depth of Field, etc. etc., then you should already know that there is no such thing as a 'best setup' for an outing that will vary a widely as a safari. You will encounter everything from action to static shots, landscape, light, dark, the entire gamut. If it we me, I'd shoot in manual and make adjustments for each setting.  My wife and daughter went on Safari a year and a half ago. My daughter took her Nikon. My wife is not a camera person so I sent her out with a Kodak Easy Share 16MP something or other set on auto and told her to just press the button. We have several of her shots framed in 8 x 10.
    • Could be a good travel lens I guess. I'd wait until there are some reliable reviews.
    • You have left it until the last minute. I don't know much about the a6000 but I'd be using Manual mode with Auto ISO. Is it Africa you are going on safari? If so, I imagine there will be plenty of light most of the time. You need to set a shutter speed to freeze any action. I would probably start with 1/1000 sec. and set aperture to just below maximum and let the ISO get the correct exposure. Take lots of shots and keep checking to see if you are getting the results you are after. Good luck.
