AFAIK, the A6000 does not have photo capture. I confirmed this with a search of user manuals. Photo capture doesn't show up until the A6100. Here's a list of all firmware updates for the A6000, there is no photo capture listed.
v3.20 (7-26-2016): Optimizes the performance of lens SEL70200GM
v3.10 (3-17-2016): The system software update for optimizing the new lenses performance. (Applied to lenses released after 2016 March)
v2.00 (6-16-2015):
Startup time is shortened.
This update enables shooting movies in 60p/30p/24p due to the XAVC S format that supports high bit rates.
For NTSC model: 60p/30p/24p
For PAL model: 50p/25p(PAL mode),60p/30p/24p(NTSC mode)
When shooting a movie in the XAVC S format, you will need to use a SDXC card (Class 10 or faster) that has been formatted after the system software has been updated.
If you format the memory card, all the data will be erased. Please ensure that the data on the card is backed up before formatting.
v1.21 (4-6-2015): Improves camera function and provides picture improvement for the new lenses (SEL35F14Z, SEL24240, SEL28F20, SEL90M28G)
v1.10 (10-30-2014): Improves the power-on time after downloading the Smart Remote Control application of the PlayMemories Camera Apps™
