Alpha 7SII record 4K with Shogun
CJT3
So I tried to follow a YouTube video to set up my shogun to record 4K video... However the only videos I've found are for the mark 1. I can't seem to get the Sony to out out 4K to the shogun, there is no setting like in the mark 1 to send 4K over HDMI. I did find a resolution setting in the hdmi menu but no matter if I select "auto" or "2160/1080" the shogun only registers the input as 1080/59.9p. Any ideas?
