A7r II stabilisation problem
DJ27
The New A7r II has the same image stabilisation bug as the A7 II had (before the firmware update)
Didn't think I'd need the firmware update for the A7r II so soon but still blown away by this fantastic camera, outstanding two days in.
http://www.sonyalpharumors.com/small-bug-warning-on-the-a7ii-image-stabilization-can-and-will-be-fixed-by-sony-via-firmware-upgrade/
I hope I get my A7RII this month. I have four lenses that I want to use with this camera mainly:
1. Minolta AF 2,8 / 16 mm Fisheye + Sony Adapter LA-EA4,
2. Sony / Zeiss FE 2.8 / 35 mm ZA,
3. Sony / Zeiss A 1.4 / 50 mm ZA + Sony Adapter LA-EA3 and
4. Sony FE 2.8 / 90 mm Macro G OSS.
Can someone tell me whether the two Sony adapters are recognized as third party lenses or not?
Thank you for your efforts!
I have the LA-EA3 and the LA-EA4 both work fine on the new A7r II.
LA-EA4 for older Sony/Minolta AF lenses with no motor built into the lens itself and the LA-EA3 for the more modern Sony AF lenses with there own motor drive in the lens.
I have a large collection of Old Manual Minolta lenses, using these with third party adapters on the A7r II I have found the in camera stabilisation does not alway kick in!
The A7 II had the same issue before its firmware update.
There is a work around by switching lenses back and forth but hope Sony fixes this issue sooooon! :)
A7r II is a super camera but I'm only four days in.
