PictureThis Posted June 5, 2015 Share Posted June 5, 2015 Using my A7s in summer sunshine for the first time I'm getting light somehow entering the viewfinder, making whole LCD glow uniformly and become almost unviewable. Its from left, and not the lens path at all - pictures are unaffected if I shoot thus blinded. Only suspect seem microphone aperture. Using the (inadequate) supplied eyecup, but its too internal for that to be involved. Anyone else? Link to post Share on other sites More sharing options...
Advertisement Posted June 5, 2015 Posted June 5, 2015 Hi PictureThis, Take a look here Light leak into viewfinder?. I'm sure you'll find what you were looking for!
mopswerk Posted June 6, 2015 Share Posted June 6, 2015 Are you sure, that it's the viewfinder? There was a discussion on the A7 lightleaks resultung from the mount, to be fixed with a single hairband: http://www.thephoblographer.com/2014/03/06/sony-a7-a7r-light-leak-problems-heres-fix ... Link to post Share on other sites More sharing options...
Golem Posted June 6, 2015 Share Posted June 6, 2015 Are you sure, that it's the viewfinder? There was a discussion on the A7 lightleaks resultung from the mount, to be fixed with a single hairband: The OP verrry clearly states that the "blown out" finder image does NOT represent the recordable image from the sensor. Therefor, that discussion [and link] is irrelevant. Maybe the 7S is just too much of a vampire to be functional in sunlight ? A few more exposures to daylight and it may just crumble into plastic dust. ------------------------------------------------- Question, re: the OP. If you suspect any particular openning or connector of leaking sunshine into the viewing optics, what prevents you from just directly testing that by blocking any such openning ? Also, since the pix are not affected, then the LCD panel should be delivering a good view even when the EVF view looks all blown away. I know it's hard to check the LCD in bright daylight, but this should be the situation. IF the LCD panel view is equally blown out, then I suspect that you need to turn off the effects view in the menu. It's possible you're using a high enuf shutter speed to shoot at a fairly wide f-stop but your effects view system cannot fully compensate. IOW, I'm describing the "flip side" of that situation where, in the dark, lowering the shutter speed no longer delivers an image bright enuf to view. ` Link to post Share on other sites More sharing options...
Karlitos Posted June 7, 2015 Share Posted June 7, 2015 It is an electronic view finder, which sees what is on the sensor. You cannot have a light leak that affects only the EVF. It's likely to be a problem in the settings affecting how the sensor image is projected to the EVF as suggested above. Link to post Share on other sites More sharing options...
