Hallo everybody
I joined this forum coz I'm having issues with my new camera, a6300, and I wanted your help to figure out if my camera is working fine and properly or if it is somehow bugged.
My issue is about noise. I'm experiencing a LOT of it. At any ISO value and at - apparently - any light condition. Talking about still images in both RAW and jpeg format.
Can you help me understand what kind of test I can do to discover if the problem is the camera or the photographer? I come from a 6Mp Nikon D40 and expected a great improvement in image quality, which I'm not experiencing. Maybe it's my fault, maybe it's the camera's ^^'.
here you have an eg, iso 100 f22 1/160
photo taken in plain daylight.
Thanks for your help and please excuse my poor English
It's not really possible to tell without looking at the raw file.
Your D40 has a lowres CCD sensor vs. the highres CMOS in your A6300.
Therefore you can expect to see more noise from your A6300, at least at lower ISO.
Ok about the low ISO, I didn't expect it but I can understand it. But here we're talking of a pic shot at 100 iso in plain daylight : )
What you see here is the same as what you would see on the raw file. I wouldn't have posted this if it wasn't a valid exemple. It is a crop of the original raw file with 100% file size and exported via photoshop at max resolution.
And I testify that it looks exactly the same as the original raw file.
So what about your experience? I really need the opinion of others possessing SONY and maybe Alpha cameras!
Thanks a lot for your answers.
Please listen. Nobody can tell you if you have excessive noise without looking at your raw file. A6000, A6300 and A6500 does show some noise even at low ISO. It will show extra in pictures of cloud or haze. If the noise is intrusive, you use noise reduction features.
You're noticing noise because you're used to a sensor type that does not show noise at low ISO. CCD sensors are better but CMOS sensors are cheaper. That's why we get them in our cameras.
Of course I'm listening, I'm here to get help ^^
please tell me what steps should I take to deliver you a solid test image to discuss on!
but I'm not "noticing" noice. I'm litterally drawning in noise! I must understand if this is the standard or if there is a problem in the camera or in the photographer b4 I spend my few coins buyng sony lenses and stuff!
What lens are you using? Also f22 is too high! Better shoot f8 or ever f16. F22 you will get a lot of refraction.
Sent from my SM-G935F using Tapatalk
The best thing would be to take a controlled test shot and upload the raw file to dropbox, posting the link here.
Like previous poster said, use a reasonable aperture like f8, by shooting in A mode. iSO 100, e-curtain off, daylight WB and all "improvement" settings off.
You can take a picture wirh cloudy or hazy skies, as that tends to show noise.
Your first picture has luma noise but no chroma noise. This is normal at ISO 100 but the luma noise shows stronger than normal (this could be s result of sub-optimal settings or background processing in your software) Doing a controlled shot and checking the raw file should limit the possible causes.
I will take the shot you are asking me as soon as a cloudy day appears here!
As for the previous image, it is straight as it came from the camera, only converted from raw to max quality jpeg, with no resizeing, only crop, via photoshop
thanks for the help!
ps lens is sony SELP18105G
That's a good picture to use. I compared it to similar pictures from my A6000. Your noise is blotchier, which makes it more visible.
Blotchy noise is more typical of high ISO settings. At low ISO, I would primarily guess at some processing flaw.
Have you tried updating the firmware? Camera should be v2 and lens v04.
so? I see I'm not the only one here concerned about it. Sony makes great cameras and expensive lenses, I need to trust my camera body if I have to invest in more lenses! yet, for my job I need to do it, on Sony, on back on nikon if I have to : (
Also the Sony Assistance stopped answering me after saing something unclear but bad sounding!
By processing flaw, I meant that the internal processing in the camera does not produce an optimal file from the sensor. This would generally be related to firmware.
Sony files are often a bit noisier than, for instance, Canon files. This may seem bad but it is actually good. It comes from the gact that Sony applies less noise refuction to the raw file. Therefore you have the ability to apply your own blend of noise reduction and sharpening.
In your case, the noise is blotchy, which makes it harder to correct. I don't know why it's blotchy. You should reach out to other A6300 users to see if you can get comparison shots. If yours are worse you should press the seller or Sony to fix it.
    • Hi all, For about the last 1.5 years I've been using the Sony a7CR combined with the 24-50mm f2.8 G lens as one of the lenses that basically lives on my camera. Besides this I have the following lenses as well: Sony 16-25mm f2.8 G Sony 14mm f1.8 GM Sony 40mm f2.5 G Sigma 85mm f1.4 On my last travel I took the above mentioned lenses with me + the 24-50 G. Would have most likely taken the Sony 14mm f1.8 GM but I didn't own this yet at the time. For my next travel I do want to take this as well so then my setup would look like: Sony 24-50mm f2.8 G Sony 16-25mm f2.8 G Sony 40mm f2.5 G Sigma 85mm f1.4 Sony 14mm f1.8 GM At this point I feel like I'm kinda reaching a bit of a limit in terms of lenses I want to take with me during travel, especially the 85mm. I wish to use it more but noticed I often left it at the hotel/apartment room I was staying at. Initially I bought the a7CR for weight savings but as time has passed I do feel certain limits with the setup especially during travel/landscape (as this is my main form of photography). And that's mainly coming from the amount of lenses I'm taking. I have been considering to trade in the 24-50 G lens to the 24-70 GMII to use on my a7CR but after using my Sigma 85mm f1.4 for an extended time on my a7CR it does feel uncomfortable to use due to the front heavy nature of the setup. The 24-70 GMII would be about the same weight as the Sigma. One option would be to use the extended grip on my a7CR, this certainly makes handling a lot better of bigger lenses but I usually have my setup hanging from the Peak Design Capture Clip on my backpack and I'm not sure if the extended grip really designed to take this much weight to be fair. Maybe anyone here has experience with this? So what this leads me to was the consideration to upgrade to the a7RV + Sony 24-70 GMII as there are some good trade in deals going on right now where I'm at. I'm not sure is this setup an absolute overkill for a hobbyist photographer... :) The benefits of this upgrade would be to have less need for changing lenses during travel and reduce the amount of separate lenses I have to take with me. The overall weight would however be approx. the same that goes in my backpack. Usually when I'm out for hikes I will currently only take the 16-25 & 24-50 with me. With this setup the reach feels limiting even with cropping the 50mm to 75mm (still approx. 26MP on the a7CR after crop). What I usually use my setup for: Landscape photography Travel Portrait Astrophotography I was wondering is there anyone here who went from a lighter a7CR (or similar) setup to a slightly heavier setup to carry around during hikes etc. Did you regret it or was the tradeoff worth it? As mentioned I do feel like my current setup is somewhat limiting and realized that switching lenses during travel is an absolute pain in the ass. But I'm not sure if the extra 450gr (about 1 lb) is worth the tradeoff. I know the decision is ultimately up to me but just like to hear your thoughts on this upgrade, and if the additional features & image quality in trade for weight would be worth it as well. TL;DR: Looking to upgrade my a7CR 24-50G f2.8 setup to a7RV with 24-70GMII f2.8 lens, not sure if it's worth it with the additional weight in trade for more versatility and better IQ. Thanks in advance for your replies!
