You mean the camera switches to the finder at a certain tilt or does everything go blank? Otherwise maybe there's a loose contact in the swivel.
What zoom function do you mean? Auto manual focus magnification? It's called "MF assist" under gear/1.
There's no contacts or switch in the tilt arms.
If the prox sensor is too sensitive there are
solutions already posted on the forum. If the
sensor is not sensitive enuf, just clean it.
Most users find the sensor to be waaaaay
overly sensitive. IOW, all is well using the
monitor until you lean in for a really close
look, and then it switched to the EVF.
