June 27, 20169 yr Hi! So I've tried searching on this topic a little bit and have been getting quite a few mixed answers about this. Like the title asks, are there any drawbacks to using a full-frame lens on a APS-C camera? For example, the FE 24-70mm on a a6300. I've read here and there that there is actually loss in picture quality, is that true? Others say it's completely fine but...I don't have the technical knowledge or experience to come up with my own confident answer. Thanks!
Advertisement Hello Igotdumbquestions, Take a look here: Drawbacks to using Full-Frame Lenses on APS-C Camera? .
June 28, 20169 yr Technically no problems, no losses. Most FF lenses lack OSS and no APSC Sony has IBIS.Whether thaz a disadvantage depends mainly on working conditions. And acoarst FF lenses are bulkier than the same combination of lens speed and FL if it were built for APSC-only.
June 28, 20169 yr In same RARE occasions, and even then only with some lenses, you could experience a slight loss of contrast due to added flare. This because some lenses utilizes baffles in their optical path or on their back to cut flare, baffles that are sized to fit the sensor (or the film format) such lenses are meant to work with. So using them on a smaller sensor means that the baffles will be a bit under-sized, and won't be able to cut all the flare. That said, this is some serious nitpicking Regarding instead the supposed loss in picture quality, the short answer is: there is none. GEEK ALERT! Continue at your own risk... The more complete answer is that when people experience a loss of quality using FF lenses on a smaller sensor body (APS-c, m4/3) what they are really seeing is simply the fact that two sensors with the same amount of megapixels, but of different sizes, will have a different pixel pitch (basically how big the pixels are). The smaller the pixels, the more performing the lens has to be to deliver. So a 24Mp APS-c sensor (23.6 x 15.7mm, 370mm2 area) is much more demanding in terms of optical quality of the lenses than a 24Mp FF sensor (24x36mm, 864mm2 area) because it is the equivalent of a 55Mp FF sensor (that is, if you extended the APS-C sensor to the same area of a FF sensor). Simple as that.
June 28, 20169 yr Biggest problem for me is carrying unnecessary bulk and weight. All my FF non legacy lenses, Sony FE 70-200, Sony FE 28-70, Sigma 105mm macro, Sigma 120-400mm, are OS so no problem there.
June 29, 20169 yr FF lenses won't be quite as sharp as lenses intended for APS-C. Wasn't as much of an issue back in the day with 8-12MP sensors, but 24MP is pretty quality hungry, being an equivalent of around 55MP FF.
June 29, 20169 yr FF lenses won't be quite as sharp as lenses intended for APS-C. Wasn't as much of an issue back in the day with 8-12MP sensors, but 24MP is pretty quality hungry, being an equivalent of around 55MP FF. Not necessarily true. It all boils down to how good the particular lens is. For example, tested on the same camera (Nex 7, 24Mp), the otherwise excellent APS-c 35/1.8 Nikon AF G DX was literally murdered at all apertures by the 50 years old Minolta MC 35/1.8. And most of my Contax glass, from 20 to 30 years old, it is sharper than many APS-c and m4/3 lenses I've used / use (and an m4/3 sensor is even more demanding).
June 29, 20169 yr Hi! So I've tried searching on this topic a little bit and have been getting quite a few mixed answers about this. ........ Aren't you glad you came here to resolve your "mixed answers" dilemma ?
June 29, 20169 yr Not much reason now to put FF lenses on an APSC Sony. No APSC Sony has IBIS, so you might as well just get an original a7, which is barely bigger than an APSC body but uses the whole image from your FF lenses. Prices on the a7 are very favorable now compared to APSC. The main question is no longer price but what feature set you need.
July 1, 20169 yr So here is one more drawback to using a FF lens on an APS-C camera basically a longer zoom. this photo was taken with my A7RII with the sel70300 at 300 Here is a shot taken with my a6300 same lens same distance same settings.
July 3, 20169 yr Not too sure what drawback is being illustrated. If you wanted to include more of the scene with the APSC you could surely zoom back to 200 ? Good clear shot ... I'm not seeing the problem.
July 5, 20169 yr Had a blast this 4th of July weekend taking photos on the a6300 using an FE 70-300mm F4.5-5.6 G OSS I picked up last week. As previously stated, this lens gets pushed out to a max of over 450mm on the 6300. I had my normal kit of a Canon 5D MkIII with a 70-210 and a doubler on it along to compare. There was very little difference in the photos but a huge difference in weight and cost. My Canon felt like a clunker next to the Sony. Compared to DSLR full framed lenses, using full framed lenses on an APS-C Sony camera has big weight advantages. Plus, I am seriously thinking of switching to the Sony full frame camera from the Canon I am currently using. I will be able to use the lenses on both.
July 6, 20169 yr ....... I am seriously thinking of switching to the Sony full frame camera from the Canon I am currently using. I will be able to use the lenses on both. Depends on what you mean by "use". Do a very thorough research on that. You can do so right here in these forums. Many variables involved.
July 7, 20169 yr Thank you for the heads up Golem. I have been checking the Sony web site and it shows lens compatibility. The lenses I have purchased show they are compatible with the A7rII and the A6300. Is there something else that I should be looking at?
July 7, 20169 yr ........... I have been checking the Sony web site and it shows lens compatibility. The lenses I have purchased show they are compatible with the A7rII and the A6300. Is there something else that I should be looking at? Now a new puzzle appears. Just what "Sony web site" do you mean. Sony's own official web site is not gonna discuss how any third party adapter does or does not preserve the operational features of Canon EF lenses when adapted to Sony camera bodies. If you researched this forum you found that adapting Canon lenses to Sony bodies has widely varied results. I have a fairly extensive Canon kit that sits mostly unused while I use my Sony E-mount bodies with A-mount lenses via Sony's own adapters. But having seen too much regretful discussion about adapting Canon lenses I do not care to put my Canon lenses on my Sonys. The forum discussions do include both disasters and successes but you get to sort that out for yourself. My personal sorting is that it's not for me, given my gear and my uses of it. YMMV, and surely will.
October 30, 20169 yr Biggest problem for me is carrying unnecessary bulk and weight. All my FF non legacy lenses, Sony FE 70-200, Sony FE 28-70, Sigma 105mm macro, Sigma 120-400mm, are OS so no problem there. This is absolutely the issue. The whole point of using an APS-C camera is smaller size, both body and lenses. I bought my a6000 thinking Sony would be supporting the product line, but they totally abandoned it cranked out FE lenses. I have no plans to upgrade my a6000 until I see some better lenses.
October 30, 20169 yr Except for the kit lenses all my lenses are FF. Since I tend to buy open-box specials, etc, the kit lenses were essentially free or even cheaper than free :-) and I used them on APSC cameras via a Speed Booster, so at least I had a benefit derived from the bulkier lenses: They were all one stop faster than they were marked and still had their original FF FoV. But with the above system, only the kit lenses have OSS. So when the FF Sonys sprouted IBIS, I got me one ... at barely bigger than the APSC bodies, and purchased used, the a7-II became the mainstay of my FF lens collection. Now that Sony offers IBIS in an APSC body, I could just as well use an a6500 instead of the a7-II. But it won't be noticeably smaller, and it will be quite a while before the a6500 shows up at a lower price, so it makes more sense to me to use my FF lenses on my FF body and use my OSS kit lenses on my APSC bodies. The only exception would be macro and long lens shots that would require more than minor cropping. Why crop the FF down to 12MP or 16MP when the APSC bodies do the cropping while still cramming 24MP into the frame ? All my macro or long lens work requires a heavy tripod so IBIS or OSS is not a consideration in that work. So, other than long lens, or macro, stuff on a tripod, IBIS and OSS are priorities governing my choice of gear, not bulk, and not sensor size. There's no major IQ difference between APSC and FF but for routine handheld stuff IBIS or OSS offers a visible IQ improvement. If there are AF performance concerns when mixing lenses and formats, I can't speak to that. Likewise if any "advanced" features are defeated by mixing lenses and formats I can't speak to that either. None of that impacts my working methods for my needs.
December 25, 20168 yr In practice, the only downside is size / weight, and potentially cost if you buy high end FF lenses. I have the A6500 and the Sony 28m f/2, the Sony 24-70mm f/2.8 GM, the Sony/Zeiss 50mm f/1.4, the 85mm f/1.4 GM, and the Sony 70-300 F/4.5-5.6 all work perfectly. The IQ is fantastic. Any talk of theoretical loss of IQ of FF lenses on a crop sensor is just that--theoretical. For all practical purposes overall IQ is significantly better, because the crop sensor does not use the borders and corners of the FF lens, so virtually all border / corner softness issues with some lenses at wide apertrures disappear. Rent FF lenses and try for your self.
February 28, 20178 yr There tend to be a misconception about FF lenses on aps-c cameras. In general, a FF lens on a aps-c body doesn't perform better than the same focal length aps-c lens on an aps-c body. A FF lens isn't build for an aps-c camera so a part of the light will never reach the sensor. The image circle of the full frame lens is wider than the aps-c lens. There are only two reason to buy an FF lens for an aps-c camera (unless of course, you don't mind spending lots of money). You want to switch over to FF and have already started buying FF glass. There is no similar aps-c version. Which in the case of Sony is often. For some kind of reason, I can't upload images so here is a link to the proof. https://lh3.googleusercontent.com/FX9WnuXMNQ5S5GQg-zBSWFBEL_-SVY5nMG_NU9bXMnlaAuLOTL-ybzczNsd0I95vndDDwvLMW1RnGNPTF2WOaapuI0nuqyWJCFmah6zResaOSs3jOAAV3AY4taSuA0kvjAiW9_X8nQoK3EtG83CC0xWhFbJyiZ8lJw5hrAJeB7LjvAGqQy_NAGOZ4SxzZdcDoUTw9PL4P1z_MfA2dBw6FZk3p2UMvQYIFLcOcWMnH1zOuqbG3FqtiZj8uf6VFAVblMwmUmcehLud65RW9fcppY2IQOrGo3mtiZeYAolAYvGd5QwzJPEjng0TAGSXRrtfH3DylKUEc7EWux6yvF521wAn1ssp8y8RLqE53zPqLik1yVHuyfXUq3ftETRp7_U0YAMIEMWsfyBlSO-LOOklu7WYBfZrD5lBXNW9xDDzL1YcwRY5-OrR8NZkceNEPh7XAXGwVO39txXgy8VNOSXDDH0dOfP1O3js_j8nHUrKVE6-HK2C4sNzyoeNxjEmvi1uvlPai_czROyA-bWO4L_rPbvnrjJe-wxN38HHOiCHaIiltJ39Ziq1IHTpSCxDTFVrULnnxZ6smPlFikzFQQLcF78jjhMC7H0sap5-sE34g1bPMf3g0z7dVQ=w2258-h1386-no And here is another comparison. The very expensive 35 Zeiss performs just as well as the cheap 35/1,8 on a Sony a600. Of course, if you switch to FF, it is an entirely different matter. https://www.dxomark.com/Lenses/Compare/Side-by-side/Sony-FE-Carl-Zeiss-Sonnar-T-STAR-35mm-F28-on-Sony-A7R-versus-Sony-E-35mm-F18-on-Sony-A6000-versus-Sony-FE-Carl-Zeiss-Sonnar-T-STAR-35mm-F28-on-Sony-A6000__1251_917_1083_942_1251_942 The point is that there people out there who can't justify or can't spend so much money of a hobby. I couldn't and there is another reason I wouldn't want to switch to FF. Most of these lenses are heavier, and the reason I went to mirrorless is because of the weight. I have arthrosis and dragging more weight is very painful.
