May 31, 20169 yr Today i want to show you my results from yesterdays portrait and streetshoot with the new little FE50 1.8 + Sony A7II. Check out my experience using the Face Detect + Eye AF. I will update this post a lot in the next days http://www.dsphotoblog.com/?p=1405 #photography
Advertisement Hello drasko2015, Take a look here: Sony FE 50 1.8 for Portraits and Street . I'm sure you'll find what you were looking for!
May 31, 20169 yr I use the 55mm Zeiss over the 50mm Sony, much much better Check out my top 5 lenses for Sony Alpha http://blog.danmleephotography.com
June 1, 20169 yr this lens has the worst AF aquisition I have seen lately. I have A7 and AF-S hunts everytime - in corners newer lock. But AF-C its great - 4x faster! I Sold A7R + 55/1,8 and bought A7 + FE28/2 + FE 50/1,8 and I'm happy. A7+50/1,8 its faster and more accurate then A7R +55/1,8
June 1, 20169 yr IQ is fantastic. If Sony fixes AF in a FW update, it's a killer lens. Have you tried the battery reset trick that someone suggested in the other 1.8/50 thread in this forum?
June 1, 20169 yr I have A7 and AF-S hunts everytime - in corners newer lock. But AF-C its great - 4x faster! I Sold A7R + 55/1,8 and bought A7 + FE28/2 + FE 50/1,8 and I'm happy. A7+50/1,8 its faster and more accurate then A7R +55/1,8 I don't have that particular lens [i use the Maxxum 50] but by your report, I'd have no problem at all with its AF behavior. You say it's terrific in AF-C ? Well, as a dedicated user of Back Button AF, I'm always in AF-C. It seems that BBAF is quite popular, so there must be lotsa happy AFers using that lens and never knowing of its AF-S shortcomings . With BBAF, AF-C functions equally and simultaneously as both AF-C and as AF-S.
June 3, 20169 yr I did notice AF is a lot faster at f/4, at f/1.8-3.0 it's noticeably slower. Doesn't bother me either way. Great image quality.
June 15, 20169 yr I did notice AF is a lot faster at f/4, at f/1.8-3.0 it's noticeably slower. Doesn't bother me either way. ........... That's just weird. That's like saying your AF is affected by your shutter speed setting. The shutter speed setting is a user input for an action that will only happen AFTER the AF has completed. I think everybody knows that, and so will not suspect the shutter speed setting of affecting AF performance. Saying that AF is affected by the f/stop settings is just the same as saying AF is affected by shutter speed settings. As with the shutter action, the actual f/stop action happens only after AF has completed. The f/stop dial does not alter the size of the aperture when you dial settings on it. Same as the shutter speed dial, it's a user input for an action that will occur at the correct future moment. Nothing changes as you twirl the dial. The aperture stays fully open [f/1.8 in your scenario] so as to provide minimal DoF to the AF, or eyeball, that's judging focus acquisition. It also provides more light to the viewing system that way. The dialed-in f/stop physically exists only during the exposure. ++++++++++++++++++++++++++++++++++++++++++++ Even selecting " Live View > Setting Effect ON " does not close the iris before the exposure. The screen darkens and lightens artificially, to show you the exposure level that your settings will produce. Exposure level is only brightness, it's NOT action blur [shutter] and NOT DoF [f/stop]. These are not previewed in " Setting Effect ". If your AF is really clearly better at f/4, if it's not an illusion, I suspect you have a malfunction. What I suspect could be either a malfunction, or an ingenious intentional function of the AF system. Given sufficient light [doesn't hafta be sunny], AF detectors often perform WORSE if shown very minimal DoF to focus with. If AF worked slowly and carefully, like we do when we MF by eyeball, then minimal DoF would provide terrific AF accuracy. Cuz AF does not focus leisurely, AF "sees better" if details are visible. AF misses lock-on and keeps hunting if it's trying to find details in the extra fuzzy world of minimal DoF. IOW, with sufficient light, it's "vision" is clearer at f/4 than f/1.8, as it views a defocused scene and seeks details that it can sharpen up. ############################################### So, given the above, maybe when the camera sees that the lighting is better-than-dim, and it also sees that the user has input f/4 [or even smaller] then the camera enables the AF to see more details and less fluffy fuzz, by dropping the viewing f/stop down to about f/4 [f/4 even if you set f/16]. And it must do that only for AF. For eyeball MF, we want minimal DoF, so we wanna do MF wide open. Trouble is, I doubt that Sony is all that clever. So in that case, if Sony is only as clever as we think they are, you may have a malfunction that lets the auto-iris kinda droop a bit, unless it's set to f/2.8 or wider. You could test that visually. If the iris is drooping to about f/4 when you dial for smaller stops, you will see a slight difference in DoF occur in the viewfinder, as you dial from 1.8 to smaller stops.
