May 6, 20169 yr Hello, I found some darker skies near the place I live. This is a median stack of 6 images taken at ISO6400 with a Nikon 20/1.8 on a A7r2. This is a panorama stitch of 6 Images - same settings made a short timelapse that night, too :
Advertisement Hi Ben, You may be interested in this: Milky Way on LSD . I'm sure you'll find what you were looking for!
May 6, 20169 yr Great images. How do you like the Nikon 20/1.8? I'm thinking it for UWA mostly for landscapes and some inside use. You images is the first combo I've seen.
May 6, 20169 yr Author Thank you! The Nikon 20/1.8 performs reasonably well. Handling-wise the focus ring is a little tricky. I have not yet tested the issue in detail but I feel as if it performs a little bit worse on my 60€ commlite nikon f adapter than on my very cheap no name adapter for 18€. It is already a sharp lens wide open and gets even sharper stopped down. Nightskies are very demanding and wide open the corners show some but not severe aberrations. Colors are mediocre. Here is a good review of this combination. Overall I would say that the 20/1.8 is a very good value option but not the ultimate uwa when paired with the A7. http://phillipreeve.net/blog/review-nikon-af-s-20mm-1-8g/ Hope this helps Ben
May 7, 20169 yr Author Had a short look again at my adapters and my commlite adapter copy really seems to introduce color fringing even at the center on the 20/1.8 my other lenses were not as prone to the bad quality of this copy so I did not notice. Better not cheap out on the adapter if you go for the Nikon.
