My Sony A-mount 70-300 G lens is not recognised by my camera, a Sony A7 mkII with lens adapter LA-EA4
Is does nothing, the Aperture sign is not visable, no reaction of the autofocus.
Sometimes, the camera closes as the lens is placed on it
The lens is a few years old, and very little used.
The same problems is there with my A6000 and the adapter.
Are ther more people with this problem, is the lens not compatible with the adapter.
I don't have a Sony with A-mount anymore so I could not test it direct on a camera without an adapter.
Hi, could be the adaptor; I use the 70-300 on my Nex-7 with the LA-EA1 and get full control and readout (auto focus works but very slowly- I use manual)
See if a friendly camera shop will let you try the lens on an A mount camera to check its OK
  • 3 months later...
