There's no forum for hotshoe/flash related chat but since you guys talk about adapters....
I own a Nikon Speedlight SB-24 and I want to use it on my Sony a7ii, already bought one adapter and I had it complete wrong.  I've been looking around Amazon but adapters aren't very descriptive or labeled well.  I can't figure out the name for the mount standard Nikon uses for speedlights, so I'm not sure what to use.  I realize an adapter won't convert the signal information, so I'll have to manually set the speedlight to the proper settings, but I just want the camera to fire off the flash at the right time.  Although if there is an adapter that can convert the signal so it knows what f stop to pick, I'd be open to spending more.  Either way I appreciate any advice you people can share.
For reference, here it the wrong one I purchased
http://www.amazon.com/Pixel-Flash-Adapter-Alpha-FS-1100/dp/B003URJP5Q/
The top mount is correct for the Nikon, but obviously the bottom isn't for the Sony a7 line
Nope the bottom on that one is for the old Sony/minolta hotshoe
I use my SB26 with a Hahnel triggerkit for Nikon. Being a fully manual setup it works a charm. Jason Lanier has a video on 4 options for wireless flash on Sony cameras. It is datid by now but should bring you some usefull info anyway.
Update: the flash works fine, no adapter needed
After further Googling I discovered the center pin is universal and it triggers the flash to fire, and all hot shoes have the center pin connector, so I charged my batteries and tried the lense, no adapter and it works.  Obviously I have to go manual on the settings but it appears the first time I tested the flash my batteries weren't outputting enough voltage.
    • Will give that a try, was thinking of doing something similar only trying a series of shots with it on and a series of shots with it off to compare. On my Nikons the VR in the lens is very noticable, was expecting something similar.
    • The vibration is the sensor. Since the A6100 does not have IBIS, you won't feel it. If you're seeing any stabilization improvement at all, it's the lens.  Zoom the lens all the way to 105mm and take a shot at 1/200 shutter to use as a control. Now slow your shutter down a stop at a time, starting around 1/100, then 1/50, then 1/25, etc. and see where the image is no longer sharp. That will tell you how about how many stops of stabilization you're getting with the lens at 105mm.
    • So what would be your reason to wait for 'reliable reviews'? We already know where it's going to fall just by its very nature.  I'm currently not planning to preorder anyway, although I keep waffling back and forth. My practical side says summer is almost over and I won't use it much in winter, so wait until Spring and maybe it will go on sale. My GAS side, however, is far less pragmatic and wants to get one upon release. I checked with my local store who is a certified Sigma dealer, and they said they will carry them but they may not have them on the 25th. Of course, the other factor is availability. It seems almost every single release these days is followed within a week or two with a statement saying that the manufacturer has 'underestimated demand' and deliveries will be delayed. That's nonsense, of course. The reality is they don't want to build 10,000 of them and be left with 8,000 on a warehouse shelf. They've all engaged in this practice, including Sony, Nikon, Canon, and half a dozen of the Chinese companies.
