December 19, 201510 yr Hi, among the restrictions of the Canon EF lens adapter for Sony E-mount cameras, Metabones lists "Direct Manual Focus mode (DMF) not supported". When I sent them an email, the reply was they had no intention of implementing that feature. Since I don't have an alpha yet, I'm a bit confused what DMF actually is and what that restriction means. What I'd want from the camera is what Canon calls "Full Time Manual" (FTM), which is a feature of their "genuine-USM" powered lenses. It means that you can manually focus at any time, regardless of the setting of the AF switch on the lens. I find this feature critical. If you combine it with a configuration where a shutter half-press does no longer start the autofocusing but you have a separate button for the AF start, this the lets you focus manually but press the AF button whenever you feel like it. You'll never have an annoying accidental re-focus occur when all you wanted was measure exposure. I would be very glad if any Sony/Metabones users could confirm if that works with Canon EF lenses on the adapter or not.
Advertisement Hello Seymour, Take a look here: Metabones, Canon EF lenses and Direct Manual Focus mode .
December 19, 201510 yr That should work. The Canon FTM is not actually a "built-in" or "additional" feature. Whenever you use FTM while in AF mode, you are just "forcing" the focusing mechanism. The Metabones adapter doesn't need to know you are doing that, and it has no way of knowing it either. Suppose you put your eyeglasses over the front lens element, which would refocus the image .... the Metabones again won't know, can't know, and doesn't need to know. You can also force some non-ultrasonic lenses in the same manner. The important difference is that after you do this a few times to the non-USM lens you may have damaged it. The USM drive lacks a solid mechanical coupling. So, when you force it you're not really "forcing" a gear train or any other moving part. The "mechanical coupling" of a USM is not a gear train or such. The coupling medium is simply air. And when that air is not activated into sonic waves, the focus ceases rotating. But it's OK to rotate it manually. You won't damage the air. The Alpha "DMF" relies on Sony's system where the focus ring is NOT mechanically coupled but is simply a data wheel ["fly by wire focus"]. I don't see why Metabones even mentions "DMF" when describing functionality of adapted Canon lenses. `
December 19, 201510 yr Hello. Is there anybody who has made practical and/or lab. tests with Canon lenses and A7RII? because until now only seen tests with autofocus behavior and not worry about the quality of the Canon lens on A7RII sensor ? Thank You
