Hi,
my sony a6400 is in good condition but lately it has a problem with focussing and its looks like a connecting failure between lens and body.
When turn on the camera it takes like 15 secondes to start up. And there is an icon with a ‘camera and a i’.
then it cant focus anymore. When i work it a bit it focusses very quickly and then its out of focus again.
i already reset the camera a couple of times - cleaned the contact pins and sometimes it does work again. but then it stops.
anyone had this problem aswel?
Thank you so much.
best, Wouter
Edited by Wouter Wouter
Have you tried it with different lenses? If not, do that next. Other than that, it sounds like you've done everything I would suggest, like resetting and cleaning the contacts. If a different lens doesn't resolve it then I think you may need to have it serviced.
Since you don't have another lens, you have another option if you have a camera shop near by.  Just take your camera in and try a different lens.  Don't tell them you are having a problem.  If the new lens works fine, that will indicate your lens is the likely problem.  Thank the salesperson and tell them you'll "think about it".  Who knows, you might buy a new lens!
If the same problem persists with the new lens, the salesperson might offer some good suggestions to try with your camera.
Edited by XKAES
Thanks! Ill give this a try.
you think updating the firmware could be a solution?
Unlikely, but you could always try. I am leaning toward the lens at this point, they can lose connectivity internally over time.
I would do cleaning with isopropyl alcohol and cotton swabs, but you may need to pick leftover whisps of cotton from the pointed contact ends on the body.
Which lens is it? You could look it up on-line to see if there are any known problems.
Edited by Cameratose
Thanks. And its a 18-135 Sony zoom - ill give it another google search! Thanks a lot for the help and advice.
So i did get another lens. Its a different one. Its a Sony lens 2.8 / 16. This one works fine. But When I put my lens on it, its out of focus again. Any advice what to do? Thanks a lot
Which lens is it? You could look it up on-line to see if there are any known problem.
