Hello,
I have a question- I am totally new to Sony A7Rv and would like to know details about how to shoot in shutter priority with the FE 70-200 zoom lens. Since the physical setting of the aperture is on the lens, does the camera adjust it automatically or do I need to set the aperture myself on the lens based on what I see in the display?
