A6700 with studio light, dark EVF, workaround?
I switched from DSLR to A6700 and am taking my first steps now to get used to it (although I have used a Sony F707 long time ago)
Situation is a still life setup. Light is from a studio flash with modelling lamp. This modelling lamp is normally on, but switches off just before the picture is taken with the flash. Remote flash commander on the a6700.
At 1/125s, F10 and ISO 100 the EVF/monitor is so dark you cannot do manual focus and can hardly see the scene. This is because the camera shows the scene as-if lit with the modelling light. The workaround I now use is to switch to auto ISO while I am composing and focussing the scene and then I switch back to ISO 100 before taking the picture with the flash.
Is there a better way of handling that? Can I force the EVF/monitor to show a lighter scene without changing exposure settings?
On my DSLR I have of course the optical viewfinder and the modelling light provides enough light to compose and focus the scene, irrespective of the setting I use to actually take the picture. The exposure has to be checked afterwards (or use a separate lightmeter for flash). A different way of working.
Never mind, I found it already.
In MENU -> Shooting -> Shooting Display -> Live View Display Set. I need to switch the Live View Display to OFF.
It will then display the scene with a bright EVF/monitor.
  • Olaf W. locked this topic
Guest
This topic is now closed to further replies.
