I recently purchased a new camera and attempted to customize the settings using the top dial. I tried setting 1 for 24fps, 2 for a frame rate of 30 and 3 for a frame rate of 60, but the shutter speed did not change on 2 and 3. What could be causing this issue?
  • 2 months later...
You don't say which camera, but I think all the Sonys work the same way.
Customising the 1 / 2 / 3 modes is confusing, but it's simple once you understand the basic idea. DON'T start in the mode you want to customise - that's the key! Set up the camera exactly how you want it to be in the custom mode. Set the shutter speed, the shooting mode, focus area, everything. Then record the current setup into the mode you want to set - record it to 1 or 2 or 3. I can't tell you the menu to use to record the custom mode because I don't know which camera you are using, and it's in different menus depending on the camera.
I tried customising 1 by turning the dial to 1 then making changes - that just doesn't work.
The good news is that you can set up a custom mode, turn the dial to that mode, and all the settings in that mode will be set, but then you can change a setting (say you change the shutter speed because you want a more staccato look) - that change will take effect immediately. Want to go back to what you recorded in the custom mode? Turn the dial to another setting, then back to your custom mode, and any change you made is gone. Basically, what you record as a custom mode is permanent until you record a new bunch of settings on top of it.
There is more to it, but that's essentially it - set up the camera how you want the custom mode to work, THEN record it in the custom mode.
    • Hi all, For about the last 1.5 years I've been using the Sony a7CR combined with the 24-50mm f2.8 G lens as one of the lenses that basically lives on my camera. Besides this I have the following lenses as well: Sony 16-25mm f2.8 G Sony 14mm f1.8 GM Sony 40mm f2.5 G Sigma 85mm f1.4 On my last travel I took the above mentioned lenses with me + the 24-50 G. Would have most likely taken the Sony 14mm f1.8 GM but I didn't own this yet at the time. For my next travel I do want to take this as well so then my setup would look like: Sony 24-50mm f2.8 G Sony 16-25mm f2.8 G Sony 40mm f2.5 G Sigma 85mm f1.4 Sony 14mm f1.8 GM At this point I feel like I'm kinda reaching a bit of a limit in terms of lenses I want to take with me during travel, especially the 85mm. I wish to use it more but noticed I often left it at the hotel/apartment room I was staying at. Initially I bought the a7CR for weight savings but as time has passed I do feel certain limits with the setup especially during travel/landscape (as this is my main form of photography). And that's mainly coming from the amount of lenses I'm taking. I have been considering to trade in the 24-50 G lens to the 24-70 GMII to use on my a7CR but after using my Sigma 85mm f1.4 for an extended time on my a7CR it does feel uncomfortable to use due to the front heavy nature of the setup. The 24-70 GMII would be about the same weight as the Sigma. One option would be to use the extended grip on my a7CR, this certainly makes handling a lot better of bigger lenses but I usually have my setup hanging from the Peak Design Capture Clip on my backpack and I'm not sure if the extended grip really designed to take this much weight to be fair. Maybe anyone here has experience with this? So what this leads me to was the consideration to upgrade to the a7RV + Sony 24-70 GMII as there are some good trade in deals going on right now where I'm at. I'm not sure is this setup an absolute overkill for a hobbyist photographer... :) The benefits of this upgrade would be to have less need for changing lenses during travel and reduce the amount of separate lenses I have to take with me. The overall weight would however be approx. the same that goes in my backpack. Usually when I'm out for hikes I will currently only take the 16-25 & 24-50 with me. With this setup the reach feels limiting even with cropping the 50mm to 75mm (still approx. 26MP on the a7CR after crop). What I usually use my setup for: Landscape photography Travel Portrait Astrophotography I was wondering is there anyone here who went from a lighter a7CR (or similar) setup to a slightly heavier setup to carry around during hikes etc. Did you regret it or was the tradeoff worth it? As mentioned I do feel like my current setup is somewhat limiting and realized that switching lenses during travel is an absolute pain in the ass. But I'm not sure if the extra 450gr (about 1 lb) is worth the tradeoff. I know the decision is ultimately up to me but just like to hear your thoughts on this upgrade, and if the additional features & image quality in trade for weight would be worth it as well. TL;DR: Looking to upgrade my a7CR 24-50G f2.8 setup to a7RV with 24-70GMII f2.8 lens, not sure if it's worth it with the additional weight in trade for more versatility and better IQ. Thanks in advance for your replies!
