April 19, 20214 yr I bought a second hand Sony a33 and replaced the battery. Since then I have an issue with a pink screen. I cannot take any pictures, and seems like it switches off when I take a picture. I have to remove the battery to switch it on again. But the pink screen is a serious issue, and phoned around a bit, but no one in SA seems to be able to assist me. Do you maybe have a solution or give me an idea of what might be the issue?
March 10, 20241 yr I have the same Problem. Screen is pink, menue is normal and i can change the settings and programms.
July 29, 20241 yr Hey, I also have this problem with my a33. Is there a solution? Edited July 29, 20241 yr by Nathan van der Merwe
July 30, 20241 yr By On 6/24/2024 at 12:39 PM, flz47 said: Have you tried a camera hard reset? By the way how do you hard reset the camera. I have the same issue as him, hav'int tried yet.
July 30, 20241 yr Try resetting the camera, then remove the battery and leave it out for a few days. If the issue is software overload, it often helps.
