I am fairly certain that the Tamron will not work. I just tried mine on the a92 and got nowhere. The online manual has the following not so helpful information:
It is not helpful as it is very hard to find the list of compatible lenses. I suspect that you might need a firmware update for the 70-200 if it is relatively old.
Good luck
Ed
  • Phase detection AF is available only when an applicable lens is attached. If you use a lens that does not support phase detection AF, you cannot use [cE08C.pngAF Tracking Sens.], [cE08B.pngAF Tracking Sens.] or [cE08B.pngAF drive speed]. Also, even if you use a previously purchased applicable lens, the phase detection AF might not function unless you update the lens. For details on compatible lenses, visit the Sony web site in your area, or consult your Sony dealer or local authorized Sony service facility.
