AF NIKKOR 28-85mm 1:3.5-4.5 - what adapter for a6000
I have a AF NIKKOR 28-5mm 1:3.5-4.5.   I think its late 1980's.  The focus ring is rubber and the focus distance info is internal to the lens, behind a plastic window.
What is the best adapter if I want to use the AF features and what are the issues,if any.
If I want to use it as a "vintage lens, manual focus what is the best adapter.
What is the quality of the lens and how well does it work on the a6000
I have a Nikkor 50mm f1.4 on my A6, and I'm using a K&F Concept adapter (F to E mount) that I bought from Amazon for around $25-30. You can also get them from eBay. Works extremely well. Seem to be a good brand. Got the idea from the guy who created Adjusted Alfa. Hope this helps.
Sent from my SM-G928G using Tapatalk
Having several such lenses on hand, and
as someone who uses adapters quite a bit,
I never put that type of lens on an APS-C
camera. It just doesn't make sense. As for
possible reluctance to let your lens "go to
waste", it has little cash value, so you can
sleep OK if it becomes a paper weight. In
the same line of reasoning, if that one lens
is your sole reason for seeking an adapter,
don't even buy a $15 adapter ... just get rid
of that lens for the pocket money it brings.
It's a perfectly useful lens for FF35 format.
But on APSC it's just a huuuge 43-127mm
[equivalent] medium speed lens.
As to AF adapters, there's no way. But for
"dumb" adapters I recommend the Speed
Booster type. These help justify the bulk
and weight of such lenses cuz the lens is
once again a wide-to-short-tele zoom AND
its new optical speed of f/2.5 - f/3.5 clearly
moots the size issue !
As to which SpeedBoosters to consider, I
can tell you by experience to forget about
the Vello [aka Commlite], the ZhongYi is a
decent if not stellar affordable choice [aka
Mitakon], and acoarst there's the King of
the Hill, the MetaBones.
All the local On-Line-Experts will insist that
the MetaBones is overpriced and not worth
the difference. If you can't go the difference
you will very likely find the lesser versions
are worth the price, not bad really. Acoarst
I don't know your finances, but if buying the
MetaBones is not painful to your pocket, do
NOT do any cost-benefit rational estimates,
cuz the Metabones PROPORTIONALLY is
overpriced. But it IS definitely the best and
second place isn't even close. IOW they've
got a monopoly on "bestness" and set their
price knowing they have a monopoly :-(
