Sony a5000 video settings help!
You'll have to play with the manual focus to get the blur effect you seek.
The A5000 is loaded with manual video features.
Indoor videos come in yellow because most homes have yellow lamp lights. You can alter the white balance even while recording video to add in more cyan (blue).
For out door shooting do the reverse and make it more yellow/red. Also use a circular polarizer filter whenever outdoors in sunlight.
