This error has started to affect my Sony a 7R3. I began to use UHS II Lexar 128 GB professional 1000 X cards and suddenly began to experience slot I errors. After insertion, formatting with camera, and several image captures, The camera freezes with an error message that it cannot recognize the card in slot 1 and it should be reinserted. After several re-insertion attempts and turning the camera on and off,  the behavior is not improved. The camera remains locked out  and slot 1 remains unreadable The error message ties up the camera rear screen display and menu system such that there is no option to format the card and try again.
These errors also occurred with UHS II Sony cards and with UHS II Lexar 64 GB cards and with UHS I SanDisk Extreme Pro cards. The error occurred at random times and would totally tie up my camera on a photo shoot. Fortunately I was able to save a JPEG version onto slot II . There is been no malfunction on the slot II cards. The camera no longer recognizes when a UHS I card such as the SanDisk Extreme Pro  is inserted in slot 1. It does recognize on occasion the insertion of a UHS II card.
The occurrence of this error is completely unrelated to any formatting of the card as I have both been able to insert UHS II cards and correctly format them in camera, and introduced cards formatted by another camera. However, UHS I cards are not recognized even if formatted correctly on an SD foundation formatting program equipped Windows computer.
After the error occurs, the image information is not lost on the card but can be retrieved by a simple card reader plugged into a laptop.
The error is very frustrating and I suspect may represent an error in the camera firmware. On visual inspection of the slot, there is no abnormality of the Pins, retaining clip, or other configuration items. There is no dirt, foreign body, or any other irregularity of the cards.
Have you found a solution to this issue ? any Ideas ? It's random occurrence occurs at the worst possible times and cannot simply be cleared by the camera memory menu choices
Thanks
  • 2 years later...
I bought my Sony a7iii a year ago, and I had no issues. Yesterday on a photo shoot, slot 1 started having the same issues with a Sandick Extreme Pro UHS 1 card. Slot 2 works fine. When I got home, I did all of the usual stuff; I found out that slot 1 will only recognize UHS 2 cards. I only have one; they are more expensive. This seems to be a problem with the A7 line of cameras. Frustrating, to say the least, but at least slot one works for now......
