May 6, 20178 yr Does anyone know of cage system (with 15mm rods for mattebox) which will fit an A7SII with the vertical handgrip installed? Thanks Doug
Advertisement Hello DouglasMunro, Take a look here: Cage to fit A7SII with vertical handgrip attached . I'm sure you'll find what you were looking for!
May 7, 20178 yr I have been looking for such a cage that would support the battery grip since I bought my a7SII in 2015 to no avail. I only find cages for the body without the grip. Would love to find one, given the battery drain when filming.
May 16, 20178 yr I spoze you'll search in vain. Given the purpose of a cage, why should it accommodate a vertical grip ? Some cages do accommodate outboard battery packs. Maybe either, or both, of you will explain to us how YOUR peculiar needs require the thing you're searching for. When you are elevated to Tsar, then your peculiar needs will trump the normal rationale of marketing and production concerns. But for now, you represent too small a user base to build for.
