​Just got my Techart adapter 2 days ago.  Downloaded version 4 of the firmware yesterday.  I was prepared for a letdown from high expectations, but it didn't happen.  I have only tried on two lenses so far--Leica 50mm Summicron and Zeiss ZM 85mm f/4--and I am more than pleased.  I am shocked at this technological marvel.  Shot at a lot of different apertures with both lenses yesterday, favoring wide open particularly when light wasn't great, and focus was very accurate.   At least for focusing people, a much better hit rate than I would have had focusing manually.
To raise an old issue, not related to the Techart adapter but rather to adapting wide angle M out lenses on the Sony A7 series (i.e. the thick stack sensor issue), what 24mm, 28mm and 35mm M mount lenses have people mounted recently that have performed well?
Thanks!
Thanks sophcat.  The Lensrentals report is very good if you typically shoot at close range, however, as one blog responder noted performance of rangefinder wide angles on Sony bodies gets worse as focus moves toward infinity.  This weekend I tested at infinity the Leica Elmarit-M 28m f2.8 II (one of the lenses which the Lensrental's report said the performance of was "useable wide open") with a novoflex adapter against the Nikon AI-s 28mm 2.8 with a Novoflex adapter and against the Sony GM 24-70mm f2.8.  The Leica was the worst of the bunch; at infinity it was nowhere near useable at 2.8; in fact, the corners were barely acceptable when stopped down to f11.  The Nikon had to be stopped down as well, but corners started looking okay at f8 and were better than the Leica's corners at f11.  At infinity at f11, the performance of the Leica was almost as good as that of the GM 24-70--with the Sony GM at 2.8 !!!
Thanks!
I don't know why the M-mount-wides/thick-sensor question is
endlessly reposted. A better question would be "What octane
rating of gasoline is the best for drowning out fires ?" I myself
just use the lowest, cuz it's cheaper and the result is identical
to super high octane.
You are soooo verrrry correct to be concerned about adapting
non-retrofocus wide angles onto digital cameras. The image
projection angles toward the off-center regions of the sensor
are far more sensor-friendly with retrofocus lenses, because
they are designed to provide clearance for the motion of the
mirrors in SLRs.
This thread's link
http://www.sonyalphaforum.com/topic/6129-regarding-smearing-of-legacy-wide-angle-lenses-on-a7-series-the-front-end-filter-solution-by-mr-haruhikot/
outlines a method that may make previously unviable lenses an option for the Sony sensor stack. Plano convex auxiliary lenses can help. The problem is, that you need to calculate the proper parameters with a simulation of a similar optical design and then you still need to find a manufacturer that offers this very lens with the suitable thread diameter.
Although the Nikon 20/1.8 is a retro-focus uwa lens designed for slr registers it still suffers from strong field curvature, but I haven't been able to find a manufacturer that offers these kind of lenses in 77mm thread versions. I guess it comes down to luck, if this approach will work. Luckily the linked thread seems to be still active and it might yield some more working examples.
Hope this helps,
Ben
    • Yes, sorry I didn't explain myself well. I've shown a picture of a cover, but maybe a cover does not protect the camera enough. I've seen neoprene covers in Amazon, but I'm looking for something else.  I need something with a zip so the camera is dust protected, with pads so it's shock protected, cool retro looking (like leather or hard canvas) and smaller than what I've found. With just the size to hold my camera with the lens.    Maybe I explained better now ;)
    • You ask about bags, but then post pictures and discuss camera covers. Which do you want? If all you're doing is carrying a camera and one lens, maybe a cover.  If you check out amazon you can find camera covers, usually in neoprene, but some in leather. That's also a good source to see different bags. When I'm shooting an auto show or cruise, I typically carry a camera/lens in a neoprene cover and a pouch with two spare batteries.
    • I recently came back to street photography after 20 years. In my 20s I used to carry my film camera around everywhere I went, I carried it on my shoulder with just the typical leather case that came with the camera (in the picture attached).  I just got my need for street photography back and so I bought a A7CII with the 40mm 2.5  I'm looking for a small shoulder bag to carry it around but everything I found is too big. I got this camera and lens for its size and I want to keep it small. Maybe I won't find a leather case like the one on my film Yashica, but something similar in size, just to carry the camera with that lens and nothing else... And if it is a retro looking bag, it would be perfect. Maybe leather (or synthetic leather) or a canvas one. The closest I've got is the Think Tank Retrospective 4, but it's still too big, I don't want to carry any extra lens.   Thanks for the help!
